I have tackled alot of small fiberglass projects in the past but nothing of this size. I decided to cut the rear skin off and go from the outside in- it seemed to be less work than cutting the cap.
Here was the sequence of events for the transom:
-cut the skin (fell right off)
-clean out the worms (circled in pic's)
-dig out the old wood (easy as most came out by hand)
-smooth out inner fiberglass lining
-glassed in another laying of mat on the inner liner
-first layer of marine ply installed (glass/cabosil mix in ALL corners)
-second layer of marine ply installed (glass/cabosil mix in ALL corners)
-third layer of 1/4' ply installed (glass/cabosil mix in ALL corners)
-transom skin glassed back in place
-knife-edged the entire seam including top cap to transom
-using 1808 and 1 1/2 oz matting glassed the transom back together
-faired entire transom
-drilled all respective holes
-transom well drains and garboard plug sleeved with pvc tubing
-transom primed and painted with Interlux paint
-thru hulls replaced with new stainless W/flappers
-new Lenco 12x18 Trim Tabs installed
-new swim platform added
Needless to say the transom is built far better than when it left the factory, and looks better too!!! NOTE: THE FLOOR DRAIN TRANSOM SCUPPERS ARE CLOSE TO 5 INCHES ABOVE THE WATERLINE, THE TRANSOM DRAINS ARE ABOUT 3 INCHES ABOVE, WITH 100 GALLONS OF GAS!
Check the pic's...
[/b]
Check the pic's...
[/b]
