Hello all. Began work on my "new to me" 1989 Sailfish 252G. I have gotten alot of great information here. I have a question about the drains located forward and outboard of the helm seats. Neither of them drain, I tried using water pressure from a hose to see if it was just a little clogged but nothing...
Any info about whether these are supposed to be connected to a thru-hull and how to access them? I will also be inspecting and replacing as needed all through hulls and seacocks, so if any one can share their experience with accessing all these it would be a huge help. I know they are going to be a PITA but they are all old plastic and look pretty old from the outside, I'm sure they need changed. What about their hole and hose sizes? It sure would be nice to be able to buy some of the material I need to replace them before I start yanking out the old ones. I can't find any information (a diagram sure would have been nice) as to the size, routing and access to hoses and thru hulls.
Im also rewiring most everything, adding new fuse distribution panel and switch panel, several great posts on here already showing some great installations. Replacing and adding an additional bilge pump, new bilge pump hoses, new oil tank brackets ( I ordered the stainless steel ones I read about here from Artec) radio etc. Windlass doesn't operate, looks like an old Lewmar, will be trying to get that checked out. Much more I am sure...
Thanks for all your info.
Dave
Dave
