I'm currently working on getting my just bought 1989 252g Sailfish seaworthy. I need to replace the deck drains including scuppers (and hoses). Right now the scuppers are white, with metal deck drains. Wondering whether to go back with the "plastic" scuppers or bronze. Do the bronze thru hull scuppers have rubber flaps in them and if so are they replaceable?
I also plan to replace all thru hulls. The under waterline ones on starboard side amidships look like a real job. She does not have seacocks on these 2 thru hulls, I don't know if there ever were. Can anyone tell me? If anyone has installed seacocks on these, how did you do it. The thru hull come thru the outer hull, then there is an inner liner which the hose passes through. Access to thru hole from inside the boat is practically impossible just to try to put hose clamps on. I will be accessing them thru a nearby 6" deck plate. I may have to enlarge that or cut a larger access area. any ideas tips on changing the thru hull and ideas about seacocks? Why aren't they there, and where/how to install them?
Thanks,
Dave
Thanks,
Dave
