1990 Grady white offshore 24 fuel float
Tucker7000
Hello,
I have a 1990 Grady 24 offshore and need a new fuel tank sender can anyone tell me the depth of the main fuel tank I called Grady in North Carolina and she did not know told me to take old one out then measure the tank depth , I would prefer to have the correct one at that time and put it in, any help would greatly be appreciated thank you all.
If you just want a plain articulated sender, there are adjustable ones that fit a wide array of tank sizes.
Here is an example
If you want to install an electrical rod type like WEMA , you need to measure.
WEMA is now KUS
Sparkdog118
Ft Myers, fl
That is a rare problem for the mechanical senders that were put in those tanks. Usually the magnetic capsule is the culprit and can be replaced without even removing the gasket. There are 2 types of capsules. One all mechanical with a needle on the sender and one with 2 wires for a gage and a needle on the sender.
