i have a 1990 sailfish i think i should replace the plastic scuppers can someone give me in depth what exactly i need to do. and maybe a website where i can order them. i have never done it.
RUMBLEFISH said:If you are going to replace the entire scupper then go to the grady white dealer near you. They sell the entire unit in stainless steel and its a perfect match and an easy job. Also replace the scupper hose from the deck to the scupper and make sure you get the same type scupper hose as they use at the factory. You should also replace all the other plastic scuppers on the boat due to UV breakdown and dont blame me when you lose some skin on your hands because its a real PITA. When i did mine I would just tap the plastic thruhulls and they would crumble apart. Scary.
Good Luck. :wink:
fearnofish said:the rest where all replaced. except the four in the back i just bought the boat thanks
GT said:Stainless steel or Bronze for the thru hulls below the water line?
jimmy's marine service said:fearnofish said:the rest where all replaced. except the four in the back i just bought the boat thanks
the outer 2 are the self bailer scuppers,the inner 2 are the splashwell drains...the splashwell drains are bronze tubes...these need to be checked for corrosion,if these fail,the transom core will become saturated with water in a real short amount of time...
