- Jan 29, 2013
Last year I bought a 1993 Grady White 209 from the original owner and I’ve been rehabbing it over the winter. I’m at the point where I need some advice. I’ve replaced all the hoses and through hulls, am replacing and resealing the aluminum transom cap, recaulking seems, replacing inspection plates, polishing hull to remove oxidation, new radio and antenna, rewiring and filling holes. There were two transducers not needed anymore (old depth gauge and paddle wheel speedometer) that I’m eliminating. There are two depth transducers I want to keep (one for Garmin chart/fish finder and one Northstar fish finder). The garmin (airmar) transducer is staying put but I thought to relocate the northstar one closer to the center line and aft next to the airmar, then glass in the two forward holes. I would need to enlarge the aft hole a bit and it would end up being 3” apart (edges) from the other. This would also keep it out of line with the roller bunk wheels. Other than creating more work for myself, I’m concerned that if I move it and enlarge the hole I’ll be weakening that area of the hull (it’s about 3/8” thick). Although the transducer shot off at a bit of an angle in the previous forward position, I didn’t notice it and the trailer wheels never damage it (I think it floats past). So, any suggestions on whether to leave it where it is (top left of pic) and glass in the aft hole (top right side of pic) or move it aft and glass in the forward hole (top left side of pic). Anything else I should consider when patching these holes? One question I had was whether to grind a 12:1 taper on just one side of the hull or both before I glass?
Thanks for any assistance you may give.
