1996 Tournament dashboard teak laminate
beachbum0831
Tournament 192
I am in search of a product to replace or repair the dashboard of my 1996 Tournament where the current panel is peeling off and want to restore it. Please advise!
trapper
Update with starboard, You can match the Grady color or go black. The old dashboard is your template. Fairly easy and would like new! Cheers trapper
If your existing panel is structurally sound and you have a bit of carpentry skill and tools, there are thin materials that can be glued to the old panel and then cut out where needed. I have seen the carbon fiber type and I thought they looked pretty nice.
Here is a link to one company that sells the panel material and also has some information and guidance. http://www.protechcomposites.com/thin-sheets/
There are companies I have seen at boat shows that will make a custom panel from a drawing or even better from your original if it is one piece:)
You should be able to find a few of theses companies on the web.
RussGW270
Here is who I spoke to. Have not used them, but when I move the vhf to the elec box and add a 2nd screen, probably will.
I am sure there are others:
https://www.tecnografic.com/
