1998 Evinrude 200 Ocean Pro idling/stalling issue
CJ7Rob
Ok guys been chasing this issue for over a year. I am having an issue where idle drops low and engine dies (more so when engine has been run and warmed up), especially when docking. Doesn't stall in gear, only at idle in neutral. Below is everything I've done or has been done by the marina( have receipts) for owner before me. I even tried running boat on remote 6 gallon tank, but still same issue. Let me know what you might recommend to check or have done next. Thanks for help!
Compression test: #1 115, #2 115, #3 110, #4 115, #6 120
Great spark (boat runs great up to 5200rpms (WOT)
Fuel tank changed 7/24/15 with all new hoses. Fuel tank drained 5/2019
Carbs rebuilt May 2019
Sync & Link May 2019
Adjusted mixtures to 7.5 turns out
Racor water separator 5/2019
New fuel filter 5/2019
New primer bulb 6/2019
Spark Plugs 6/2019
Thermostats 6/2019
Blew air thru fuel vent hose
New sending unit ( fixed fuel guage)
gradywhiteman
connecticut
not sure if your engine has these, timer base? shift switch? powerpacks? electronics can be tough to troubleshoot. do you have a vro pump?
could be something on the fuel side of the pump.
Topjimmy
Washington state Coast
I do not have the Evinrude but my 1994 150 Yammy had done that for years when warm and it would piss me off and no matter what I did like you carb rebuild fuel cleaned, new fuel pumps adjust timing Blah blah blah and when I tried to dock it would kill, so I just turned the idle up a little higher problem solved it idles a little fast when cold but oh well
CJ7Rob
Sometimes after anchoring for a while, I start it up before I pull the anchor and I have it throttled forward a bit in neutral at about 1200-1500rpms to get it warmed up. Once I pull the anchor up go back to the helm and I pull back into neutral and go to put it in gear, it just dies. Start it up again, it might die again, or stumble and move forward a little bit and then die. This might repeat a few times until it gets enough gas to take off. I noticed yesterday when I push in the primer though it will help it take off easier. I don't think its a fuel quality issue, just some kind of intermittent starvation issue.
Paul_A
Going by memory which is fuzzy but I had a 97 ocean pro with the same issue.
Ended up being misadjusted throttle cable. The sync and link on that motor needs to be about perfect so I would get the factory shop manual and take the time to do it myself.
It sounds like everything else is in good shape so I believe it's an adjustment.
CJ7Rob
Wondering why it would happen intermittently? If cable was misadjusted and sync and lync was off, wouldn't it miss and idle incorrectly all the time? Someone mentioned plugged idle jets too, same deal why would it run good in the beginning and then have a problem once warmed up? Thx
Paul_A
My issue was similar to yours in that it only happened after the engine was run for a while. I have no idea why that was the case. Hopefully someone else can help you out.
mleads310
Brooklyn NY
I had the same exact engine and same exact issues. If I remember correctly I adjusted the throttle cable to run a touch on the high end of idle rpms.
CJ7Rob
Thanks, I was wondering if I do that, will it clunk going into forward and reverse, and would that be bad for the gears? Did you adjust this at the cable or one of the linkage adjustment screws?
