2” of Water always in mid ship bilge of 360 express - want to get it out - “Bilge-B-Dry” question
Express 360 Finally
Cape May,NJ
Express 360
My 360 express sits bow slightly down at the dock holding about 2 inches of water forward of the mid ship seacocks and bilge pump. Water flows to the stern when underway but it isn’t enough to run aft bilge to completely remove the water. I shop vac every 2 weeks and remove about 5 gallons of water from rain, wash down, etc that drips into the hull. I’m tired of dumping bilge cleaner in that area and want to alleviate the mold risk, dampness and odor.
I want to install the Bilge B Dry system with 2 pick ups in the forward bilge connecting that pump motor to my bow thruster deep cycle battery with the small discharge line spliced into the head sink drain line. Has anyone installed Bilge B Dry?
I did this on my 330. Works great...
Suggest you use 1/8" clear tubing. The thinner tubing sucks the water better.
I also put a couple small lead fishing weights (like quantity 2 4 ouncers) on top of the faceplate to keep the intake sponge from floating around down there.
You can easily buy the pump on Amazon and the rest can be purchased at your local HW store.
