- Jun 5, 2020
- Age
- 62
- Santa Cruz Mountains, CA
- Website
- mcvoy.com
- Seafarer
Crab season is just around the corner, I bought some EZ pull pots and a Scotty puller. I mount my downriggers and the puller in the rod holders in the gunnels. I've been warned that putting that strain there will give you hairline cracks in the gelcoat eventually so I have a plan which leads to some questions.
My plan is to make a brace out of HDPE (plastic cutting board material, strong and easy to machine). Sort of an eye bolt shape where the eye goes around the base of the rod holder and then extends over to the side of the boat. I'd make that end of the bolt in a sideways T shape so I have something to work with when I attach it. The idea is that brace is now keeping the rod holder from moving, it would have to flex the side of the boat to move the holder. If I can make that work, seems like a much stronger setup.
Which leads to my questions:
A) How think is the fiberglass on the side? Is it thick enough you can screw a screw in there?
B) Is there any glue that would glue HDPE to fiberglass?
and even
C) Am I thinking about this right or is there a better way to brace that rod holder?
and even
