2001 Marlin 300 Upholstery
Phil
British Columbia
Does anyone know how to remove the cockpit cushions/upholstery in a 2001 Marlin? I thought it would be through bolted but it looks like it could potentially be screwed in with no access to the screws
For the side bolsters, get down on your knees and locate the brass or aluminum grommets on the mesh material. Locate a phillips #2 screw inside the grommet and remove. On larger pieces there are three, on smaller two. Then push them up, they slide off.
Phil
British Columbia
Thank you!
No prob. Are you recovering yourself? The bolsters are very easy to do.
