2004 Gulfstream port-aft window leak
coldpizza
Los Angeles, CA
It seems my port-aft window leaks after washdown or rain. I feel that it is the gasket where the 'glass' contacts it. The window is openable. I'd like to find the gasket and replace it, before I consider resetting the window in the hull. Any idea what it is? I will call Grady at some point if needed.
TIA.
Len
hooked on Grady
northern New Jersey
I sent mine out for restoration, Boat glass specialties. Wasn't cheap but very pleased with the outcome. Butyl tape around opening before resetting the windows, they should remain leak free for a long time.
that said you cold probably get what you need from them as well. Speak to Tex.
Reactions: coldpizza
coldpizza
Los Angeles, CA
Thanks, I'll look into Boat Glass Specialties.
