2007 305 GW express trim tabs
tdc
Does anyone know the piston size or part number of the bennett trim tab piston on 2007 GW express? Need to replace mine but its not on the parts manual.
PDX-Boats
Mine is at the shop getting new canvas but I'll probably go check on her on the next few days and will look at what my 2008 model has for you
tdc
Thanks, GW gave me part number GW 18-511 but it is the entire kit with the controls, cables, trim plates, etc. I need the actuators only and not replace everything. Was thinking of replacing o-rings on each but cheap enough just to buy 2 new ones and replace them both.
Thanks for responding, I need the size or part number of the actuators only.
tdc
Take a picture of the hyd ram and call Bennett directly - they'll help you.
Thanks for the reply, talking to Bennett and will see if they brakdown the part numbers from the GW 18-511 kit to find the actuator part number.
