2018 GW Freedom 235 Stern Cleats Failing
Eyeball007
Freedom 225
I have a Freedom 235 that I bought last July (2018). I store it indoors in a boatel, and take it out weekends where it is moored in a slip.
Today I noticed a tiny space between the stern cleat base and the fiberglass of both stern cleats. I pulled up on the cleats and both come away from the hull enough that I can see the two posts and the holes they fit in.
Has anyone ever seen or heard of this problem before?
Capt Tom
Miss Gulf Coast
Freedom 205
Man that is not good. Not sure if I am sold on these style cleats to begin with.
Send the pic to gw via the web or see your dealer.
bFransen
There's got to be a nut under there that you or whoever sold you the boat can tighten. If not, something needs to be fixed before that does some damage to the hull or fails.
That should not happen. Obviously, whomever tightened installed that cleat at the factory did not do it fully. The sealant (slightly adhesive) was the only thing holding it tight to the hull. It finally gave way. Your dealer should fix for free - or add new sealant and tighten the nuts yourself.
I tend to think that the cleats were bedded with sealant, pressed into place and then somebody forgot to tighten the bolts. Call Grady service.
Reactions: SmokyMtnGrady
SmokyMtnGrady
Yep....take photos and call the dealer and Grady if need be. This should be an easy fix and warranty issue.
