2022 Canyon 271 Seacock location question
Kwest202
I'm trying to confirm that the seacock in the front bilge area is the holding tank discharge valve.
I have other questions from owners if they are willing to listen.
We bought the boat at the end of this summer and are still learning about it.
Thanks.
Ken West
2022 Canyon 271
Irvington, VA
You have a bracket for 2 pull shafts, how many through hulls/ seacocks do you have there? The one you show is in the water inlet bracket, nothing in the discharge bracket. Do you know if you have a fresh water, or raw water/salt water flush head? If fresh, you only need one discharge through hull. Where is the deck fill/pump out for the holding tank, in that area, or at the stern??
It looks like the left side says Head Inlet and the right says Head Discharge. Since there is no lever, as mentioned you may have a fresh water toilet
Reactions: Kwest202
