- Nov 9, 2021
- Age
- 53
- Fisherman 222
Picked up a 222 fisherman a week ago
Grady’s have a few common problems - one is the breaker in the aft. That’s a main breaker and the electrical system is powered via that - problems with the breaker are a common thing.swapped that breaker for a real breaker. Added a separate breaker and ground to power a fuse box dedicated to electronics. Added another breaker and ground to power and ground the autopilot on order.hydraulic autopilot pumps need a clean source of power / ground as well as electronics - the very reason to do what I did.
A “sense” relay was added to allow both batteries to charge,while the motor is running, keeping the batteries electrically isolated.a smart move !
A 36v system was added to power a 36v 112lbs i pilot .power and ground is 6g cable, in a weave loom protected coating - this prevents chafing.the power /ground cables run down the rigging tube to the Stbd aft battery compartment - these are junctioned off to an additional set of cables, running up the starbd side, to the bow.
All the battery cabling was replaced as well - battery cabling was 6g, no good ! Replaced with 4g covered in a weave loom.the old battery cables were automotive copper, as well as the terminal ends - no good !
Another problem Grady has is the scupper hoses will deteriorate, people often overlook these,resulting in serious problems. I’m changing those,along with the rest of the hosing on the boat - another smart move !
Look into these things ….
