- Jun 16, 2015
- Brisbane, Australia
- Seafarer
I have a 228 and absolutely love it. It's big enough for offshore and small enough I can trailer it home. For me, going bigger wasn't an option so I'm super happy that I got one before they stopped making them.Well, bringing this thread back to life, it looks like they've discontinued the 228 as well now. So just 208 and 232, no more Seafarer line. They've had a Seafarer for as far back as I can tell. Seems like a big move for Grady but as someone pointed out, maybe they come up with some sort of 208 / 228 hybrid replacement??
I currently have a 1996 208 and have a 228 on order. It is supposed to be shipped out of the factory June 7. For me it's the largest one that I could fit in my slip.I have a 228 and absolutely love it. It's big enough for offshore and small enough I can trailer it home. For me, going bigger wasn't an option so I'm super happy that I got one before they stopped making them.
I think it is a shame, on the west coast those 228's are well loved and for good reason. The 208, nice as it is, is too small, be really hard to crab out of that boat.
I looked at the 208, it's $30,000 cheaper. 200hp instead of 250hp, transom instead of swim platform, and 2 feet less cockpit. I suspect that if Grady didn't up the price so much, they would have sold more 228s.I currently have a 1996 208 and have a 228 on order. It is supposed to be shipped out of the factory June 7. For me it's the largest one that I could fit in my slip.
I was searching for a newer used 226 but they are just so hard to find. Where I keep my boat is a perfect protected spot I've had the slip over 25 years. The 228 should just fit. I originally went with the 250 hp but after speaking to a few people, I upgraded to the 300. The additional cost was only $2200. So far they said it's scheduled to be built on time. Just hoping all goes wellI looked at the 208, it's $30,000 cheaper. 200hp instead of 250hp, transom instead of swim platform, and 2 feet less cockpit. I suspect that if Grady didn't up the price so much, they would have sold more 228s.
Whatever, you are going to love your 228. If you have following seas where you are, you'll have to get used to the swim platform pushing you around, that's weird the first time but you get used to it. Other than that, all the surprises are pleasant ones. My 228 is a dry boat, I never have water coming out when I remove the plug. Just a great upgrade for you, enjoy!
I have the 250 and I think you were smart to get the 300. Not for the 47 vs 50mph top speed, who cares? It's for the hole shot, when it is lumpy out there the 250 struggles a little to get up on plane. I'd have bought the 300 if I knew then what I know now. You'd be fine with the 250 but you'll like the 300 better and they are nearly identical in MPG.I was searching for a newer used 226 but they are just so hard to find. Where I keep my boat is a perfect protected spot I've had the slip over 25 years. The 228 should just fit. I originally went with the 250 hp but after speaking to a few people, I upgraded to the 300. The additional cost was only $2200. So far they said it's scheduled to be built on time. Just hoping all goes well
Thank you for your posts. I followed all of your progress in setting up your boat with the electronics etc. I learned a lot following this site and made some changes to the boat as we went on. After learning that the CL seven is actually a Garmin 7 inch and Will connect to the Garmin electronics, I ordered the 8610. Grady is going to not mount the door to the electronics box nor drill the holes for the hinges. The company that will do the electronics install is going to make a carbon fiber panel and we are going to flush mount the 8610 and install two transducers. One brass through hull and the Garmin larger transom mounted. At this point all of the electronics are in with the exception of the radar unit is back ordered. Hopefully that will come in by the time the boat gets here. If not, I'm hoping we can just install it later. Again, following the posts on this site, I've answered a lot of the questions that I had in my head.I have the 250 and I think you were smart to get the 300. Not for the 47 vs 50mph top speed, who cares? It's for the hole shot, when it is lumpy out there the 250 struggles a little to get up on plane. I'd have bought the 300 if I knew then what I know now. You'd be fine with the 250 but you'll like the 300 better and they are nearly identical in MPG.
Enjoy your 228 and be happy knowing you got one of the last ones made. Great boat.
This site is awesome. It's big enough that there are a ton of 228 owners here, Marlin owners, etc. You can ask any question and get good info. If I have helped, that's great because I've learned so much here, if I'm giving back a little, feels good.Thank you for your posts. I followed all of your progress in setting up your boat with the electronics etc. I learned a lot following this site and made some changes to the boat as we went on. After learning that the CL seven is actually a Garmin 7 inch and Will connect to the Garmin electronics, I ordered the 8610. Grady is going to not mount the door to the electronics box nor drill the holes for the hinges. The company that will do the electronics install is going to make a carbon fiber panel and we are going to flush mount the 8610 and install two transducers. One brass through hull and the Garmin larger transom mounted. At this point all of the electronics are in with the exception of the radar unit is back ordered. Hopefully that will come in by the time the boat gets here. If not, I'm hoping we can just install it later. Again, following the posts on this site, I've answered a lot of the questions that I had in my head.
