230 Fisherman vs. 257 Advance
Frank
What are your thoughts on the differences between the new Fisherman 230 and the existing Advance 257? They are both around the same weight.
* Fisherman has 21.6 degree transom deadrise vs. standard 20 degrees of Advance, so it should ride better but the Advance has a longer waterline (I assume) so it may ride about as well. Has anyone ridden on both?
* The Advance can take twins but the Fisherman is limited to a single. Some have indicated here that the twins handle better, but perhaps the new light weight Yamaha 300 reduces the difference in handling between a single and the twin 150s (I know there will be some benefit to the second engine, but at increased purchase and operating cost).
* The Advance has a nice transom fishbox, greater fuel capacity, transom door, bigger cockpit.
What other advantages are there to one or the other and does the Fisherman 230 fill a niche that is different from the Advance? Any idea on whether there is much difference in pricing?
Frank
I thought I would bring this back to the top. I am surprised no one has any thoughts on how these two compare. Other than a different hull with more deadrise, I am having a hard time seeing how the 23 improves on the 257 unless it is substantially cheaper.
BobP
We don't have any owners here for more than this new model too.
I liked the 230 also, had a full rigid stern and flush coming pad straight across even though motor on transom design.
Single engine only possible but allows big transom cap wells.
Frank
I would have thought owners would be using at least a couple by now.
What do you guys think as compared to the Advance? The Fisherman 230 seems to give up a lot to the Advance (no transom fishbox, fuel capacity, transom door, cockpit space and length). With the increase in deadrise and better ability to work a fish around the transom/motor, I imagine Grady is targeting the Regulator 23 class of boats, but I am having difficulty in seeing it as a major improvement over the Advance. Am I missing something?
fishinmission
25 ' Advance
I have had mine since 2005 and it is the best boat I have had..... even against other Grady's ..... I take mine to the Canyon and back (70 to 90 miles each way , Shark fish or the back bays it always gets better then 2 MPG with twin 150's.... a t-top is a must it rides like a big boat ......So Far 450 hrs a only maintenance work....
Good Luck
Frank
What speed are you running on those long trips?
fishinmission
Fuel Burn 25' advance twin 150's
I can run 4000 rpm with 4 guys Ice and Full fuel and get 30 mph ......and as I increase rpm's it stays over getting 2 mpg which is great . 4000 rpm is the sweet spot .
I have left my slip at 4:30 am come back at 7:30 or later on a Basically flat day burn 100 gallons of fuel and trolled all day. if its rough out I can use 115 gallons.......Make sure your props are in great shape..that is key
