235 Anchor question
Basterra
Hello, all. I am installing a bow roller and windlass on my 235 and want to know what kind of anchor you recommend to go with the OEM system. I was considering the Delta (galvanized, 14lb). Will this fit appropriately? Is the 22 the right size instead?
Either delta or plow. A 13 or something a little heavier. Depends on where/what kind of bottom you are anchoring on.
Took me a little while to get around to refinishing the boat pulpit after the rework for the pivoting roller.
Delta is a brand of plow anchor. So, yes, generally a plow style is the easiest choice. But that's not to say other styles won't work - it all depends on the roller setup and the proximity to the bow keel.
14lbs is MORE than enough for a small boat. Especially if you have chain. But even with all rope, it's still plenty. If it fits, it never hurts to go bigger, though! But 14-pounders are used on boats bigger than yours.
