248 Voyager Tank Replacement
fordfisherman
ct
Replacing both the 56 and 105 gallon tanks on my 96 248 Voyager. The 56 is installed with new hoses and hardware- no issues.
The 105 looks to be quite a bit more involved to swap out. The tank runs about 10” under the main deck and it looks like cutting the bulkhead may be the only option for removal?
Anyone done this? Any info appreciated- Thanks!
Cutting the bulkhead is likely your only option.
I'm facing a similar situation with my 1997 268 Islander. I talked to an experienced fiberglass shop near me and they confirmed that my bulkhead had to be cut out to get the tank out. With Aux tank removed there is not enough room to get the main tank out. My tank is 60" under the steps and deck! They may have to take a second bulkhead out. Fiberglass repairs, if done right, can be 100%. They were confident that the bulkhead repair would be good as new.
This photo isn't my boat but it is a 268 Islander. Looking from port side aft. The aft tank is fully exposed and "easy" to remove. The forward tank is only exposed about 10" and extends forward under steps and deck about 60".
Looks good! Apparently you can get your tank out of the forward deck.
Needed a shoe horn and some silicone spray. Not sure why Grady designed it that way.
I have a 98…same boat. Where did you get the tanks?
AGM Tanks in Florida. Nice fab work at a good price. I sent the original blueprints from Grady White customer service and Matt from AGM did a great job.
any pis of the 56 gal au tank install? i don't hae that on my 2002 Voyager but when the time come to replace the main tank will consider adding. any and all pics of you project greatly appreciated.
The 56 was easy to replace. I think the harder part for you would be adding the fill and vent hoses.
I expect your right bout that. Did you replace your fuel hoses when you did the tanks?
New fuel hoses and clamps. Should be good for another 20 plus years.
This ethanol fuel is real garbage. Killing our motors and fuel systems. I cut open the old fuel lines and they had brown mush on the inside; even running a 2 micron fuel water separator, my filters would clog in short order along with water getting into the fuel system.
i agree with you 100%. sounds as though you did the job right. Best of luck this season.
My 97 Voyager has the filler and vent hoses already rigged and I believe the fuel line running aft is also pre-installed.
Been 10years since I looked inside the Aux tank compartment so I am not 100% certain about aft fuel line.
Hi Ford - I am sooo glad I found another 96 Voyager 248 guy!! (In fact, I also have a Honda BF250 - 2021.) (I think your location is CT. Ironically, I am from Rowayton, CT, but have temporarily moved to Hillsboro Beach, FL for a while.) My boat has only the 105 tank, and I am now at the point where it has to be replaced. If I understand your picture (of the 105) you did NOT have to cut under the helm/chair area. I made a similar measurement of the tank running approx 10 inches forward under the helm/deck area. I also measured approx between 1 and 2 inches of space between the aft-end-of-the-fuel-tank and the tank area aft bulkhead. I hope you had a similarly small space there - since you were still able to get the tank out/in. On a positive note, there is space above the tank for maneuvering. Although barely readable, the label-glued-to-the-tank indicates Florida Marine Tanks, model FMT-105-GW. I figure getting the tank made is the least of my problems. Getting it out/in is the problem. Even though you did it, I have a bunch of questions: 1) was the tank foamed in anywhere?, 2) There are 2 removable sections of the cockpit deck - the small aft one (gives access to the washdown pump etc) and the bigger main one that covers the main fuel tank. I have removed/resealed the smaller/aft section in the past, I haven't removed the main section yet. In your picture, I see the white-plastic wedges screwed in to secure the tank - are those the original, or did you have to have new ones made? Was the wood/material that they are screwed into still OK (not rotten, holds a screw)?? 3) Regarding the seam between the main cockpit section (covers the tank) and the smaller section (covers the washdown), if both are removed (as in your picture) is there usually a piece of marine-ply (a few inches wide - used to screw in the cockpit deck sections in that area) on top of the bulkhead-that-separates-washdown-and-tank?? And if so, did you have to cut it out to get the tank out? 4) did you have to do anything to the bed where the tank sits? Did anything need to be restored there, or replaced?
I could obviously use some guidance here - especially from you, since you've been very successful with inflicting minimal damage during this process. Glad to talk over the phone if that's less painful than typing. Desperate!! :-)
Thanks very much for any feedback, in advance.
Cheers,
Jim K
Hi Jim,
It’s a pretty straightforward R and R. Those white blocks are from the factory and are held in with screws. (No foam). The tank sits on strips of rubber and I re used the originals. The only cutting required was the strip of marine plywood between the large and small hatch covers was rotted so I removed and replaced with 3/4”Azek. It’s a shoehorn fit when angling the tank into place but doable.
Call Grady White customer service for the build specs on the tank if you have a local fabrication source. GE Almond silicone is a great match for filling the seams after installing.
Hi Jim,
You could also have the new tank made 6” shorter to make the replacement easier. Would be a minimal reduction in fuel capacity.
Hi Ford - I Really appreciate the additional info/response. I left a msg with GW parts. (They sometimes are "slow" to respond to matters related to old boats like the 96.) I am very encouraged that they gave you the tank build specs. If they are slow to respond to me, is there any chance you could send me either 1) info on how to contact AGM (could not find them on internet - did they change their name?), and/or 2) the specs for the 105 tank (as you got them from Grady)?? Regarding your idea of making the tank 6 inches shorter...I had thought about this (actually 1 or 2 inches cuz did not want to give up that much fuel). However, I am semi-optimistic in that you (with difficulty) did get the tank in/out. Was it enough of a nightmare that I should def consider shortening the tank? Or do you figure a tank-by-spec should usually fit (with pain)?
AGM Tanks
(863) 514-0904
Matt Gil
I’ll see if I can find the build specs from Grady.
