- Aug 18, 2011
2002 265 Express. Want to install in hull wet box for m260 transducer. Near the transom on both sides of the keel, Grady put seacocks. One is for the washdown and other is for the livewell. I also have oil tanks installed on the flats on both sides of keel for the 2 strokes so that area is off limits to install the wet box. I think if the wetbox is behind either water pickup there will be turbulence generated by the strainer/pickup and will affect the transducer. Has anyone relocated the pick ups and done this modification. Need an area of "clean" water.
