- Nov 9, 2022
- Express 265
Good morning! Finally getting to use the 265x and it’s great! My aft bilge pump comes on pretty often and it has me concerned. I went searching for leaks by myself but can’t find anything. When others are on board, it happens. This leads me to believe it’s a scupper issue. Earlier this year I changed the hoses but used the existing through hulls. They didn’t appear to be defective on land. The boat is kept on a lift so it’s not easy to check externally until December when I pull the boat. As long as I have the new bilge pump I’m comfortable with this and I’ll flip the switch often to monitor. My question is, is there anything else that I should check? I don’t think that anything else would go below the water line with extra bodies in the cockpit.
2003 265ex with F225’s from the factory. maybe 20 gallons in the auxiliary tank versus over a hundred in the main tank.
