285 Freedom on a 10,000lb lift... any issues?
Anyone have a 285 Freedom or similar on a 10,000lb lift? The wet weight of the 285 is around 9,400lbs. If the advertised capacity of the lift is 10K, then it's probably fine up to around 11-12K. Just curious if anyone is in this situation.
I have a 12k lift and a 306 Canyon that is 11k wet, I don’t fill the 290 fuel tank more then half and I load the boat with people while in the water. So far everything is working well. Keep up on lift maintenance for sure.
