33 express generator
mornin' sun
avalon new jersey
just bought a new (for me 2007)33 express and according to the label on the electrical panel it said not to run the boat at cruise with the seacock open to the gen.. Now the question is here I am running to the cayon and want the ac or refrig on.. can't i run the gen? or do I run these off the batteries till Iam trolling??? Help..
Coconut330
Port Orange Florida
I run mine all the time while running. No problems. If you have freezer plates or want to have AC Kinda stupid to have a gen and not be able to use it. I know other people who run theirs also. What did the previous owner do? Was there any problems?
ElyseM
highlands, nj
call gw and ask them about your specific year. for mine (2009) the genset can be run while underway, but the seacock CANNOT be left open underway if the genset is OFF. i have a pancake intake under the boat. i don't know if they used scoops earlier. they will tell you directly. ron
Reactions: loubeer
georgemjr
Bay Shore, Long Island NY
From what I understand the problem is not running while running the generator, it is running with the generator off, but the seacock open. This situation can allow water to back up through the exhaust of the generator. General rule: run the generator whenever you want, but always close the seacock when you turn it off.
Reactions: loubeer
seabob4
Weeki Wachee, FL
Generators should never have high speed, or "scoop" type pickups for the intake, and I'm sure GW installed the correct intake t/hull, with an external strainer. I think they are worried that, regardless of the correct install, some water could be forced up into the intake, past the pump, and some how make it into the gennie cylinder head. I doubt that will happen...
NOTHING ELSE MATTERS
LONG ISLAND NEW YORK
That is correct.
Reactions: loubeer
There is NO high speed pick up, but they give you the warning "just in case" might have a problem, but should not be a problem anyway. They use the same type of seacock for the live well(s) and even with the live well motor shut and the seacock open, i never get water in the live well. But for a good measure keep the gennie seacock closed when not using. Well, keep all the seacocks closed when not using.
gulfcart
Palm Harbor, FL
I run mine all the time while under way. If you have it open and not running it has the possibilty to "hydro lock ".. I installed a fresh water flush system on my Gen, forgot to open the valve when flushing once and the fresh water backed up into the gen.. Locked it up tight..Had to pull the injector to free it up. No damage but if it had been salt water it could have been a different story.
JoleGW33
Puerto Rico
generator
can I run my gen while running? i heard that if air gets in the system it could cause the engine to overheat because it would not be able to suck in water.
Is this common?
Re: generator
Is this common?
Yes, you can run the gennie while underway. If she is plumed correct you should not get air in the system.
seabob4
Weeki Wachee, FL
Re: generator
NOTHING ELSE MATTERS said:
Is this common?
X2. We run ours at 50+ MPH...
JoleGW33
Puerto Rico
Re: generator
Is this common?
thanks for the info! what kind of gen are you running? and in what GW?
gulfcart
Palm Harbor, FL
I've run mine for days at a time when on fishng trips.. Never missed a beat.. Ditto at 40+ mile an hour.. Never a problem. 33 Express with a Panda. 600 + hours on the gen.
seabob4
Weeki Wachee, FL
Re: generator
JoleGW33 said:
Is this common?
Proline 32 Express, 5KW Westerbeke. Pickup about 5' fwd of the transom...
JoleGW33
Puerto Rico
Re: generator
seabob4 said:
JoleGW33 said:
Is this common?
Ok Thanks, hope everything stays well, I have a Panda on my GW 33express
seabob4
Weeki Wachee, FL
We used to do Panda 3s on our 29...no problem. Switched over to Westerbeke 3s so we didn't need the diesel tank, and all the control boxes that come with the Panda...
Fin-Allie
u need to close the sea cock if running the boat and the gen, is not running so water dont push into the cylinder thru the exhaust .
everwhom
Cape Cod and Nantucket
For what it's worth, I forgot to close the seacock several times on my 330 with a factory plumbed FP without any problems. But it died of other natural causes after 20 years and I replaced it with an inverter system. LOVE the inverter -- best upgrade I've done.
