- Dec 1, 2018
- Age
- 47
- Express 330
I was suffering from a pretty wet stinky bilge in my 330 express, for a number of different reasons. But mostly, the 1500 gph rule pumps that were in there would still leave about an inch of water sitting in the bilge.
As I was digging around, I discovered the aft floor compartment in my aft cabin. In my boat (not positive this was factory) this rear box was getting water in it, because the 6" deck plate in the back of it (aha) wasn't completely watertight. So if the bilge had 4" of water in it, that box had 1" in the bottom. Now that I'm saying all this I'm suspicious that deck plate WASN'T factory so would be very interesting to hear if it wasn't and on most boats that compartment is watertight? There's a good few inches between the back wall of that "bin" and the rear bulkhead. Mine had some long-since-unused raytheon sensor in there.
In either case - I popped that plate out and installed one of the "electronic timer-based" 500 gph rule bilge pumps that everyone hates via a little 5 minute epoxy in the strainer basket. I plumbed that to a new 3/4 line, which I ran across into the port side aft cabin wall compartment, behind the freshwater/washdown pumps and out the side.
Voila. Since I'm on shorepower I don't mind the occasional bilge check - you DO hear it in the cabin if nothing else is running - but it is a small enough pump and that location seems just right that it's sucking out a good bit of water that was otherwise sitting amidships.
