335 Express Grady White, 2005
bwallbom
335 Express Grady White, 2005. 2 Repowered Suzuki 300's ... and having a problem with selecting the right propellers . Cannot trim out the motors without causing cavitation . Any info would be appreciated.
ElyseM
highlands, nj
can't help with those, but i put XL4s on my 2009 with F350s. virtually no ventilation, increased bite, and stable mpg over a wide rpm range. i lost about 3-4 mpn on top end, but i don't do top end. good luck, ron
Suzukis are geared for big props.
Go BIG. Go 4 Blade
For reference I have a 265 express with suzuki 200s with 4 blade 15.25 x 22.
Also, don't get hung up on max rpm. There is a range for a reason.
bwallbom
if the XL4 that seems to be used with Yamahas are available for Suzuki engines. Would you expect the same kind of performance?
ElyseM
highlands, nj
you'll have to ask the dealer (or prop specialist). mine did run pretty much on point to the Yamaha perf bulletin.
suzuki has its own line of 4 blades or look at Powertech OSF-4 (15.25" dia) or LSF-4 (16"dia)
Yamaha F300 has a 1.75:1 gear ratio. Suzuki DF300 has a 2.08:1 gear ratio so one would expect to run a bigger prop
(more precisely, you would expect the suzuki to rev higher with the same prop as the yamaha, all other things being equal)
bwallbom
Thanks goes out to everyone who has contributed to our question!!!
We just cannot seem to find a prop selection matrix for our 335 Express with the twin 300 HP Suzuki. The 4th set of props the dealer has tried, and that are on the boat now, are Lexor Plus 9572-160-19. Maybe some additional information might be helpful. The first set of props were "standard factory recommended" and they just were terrible as you could not get out of the hole - just ventilated.
At some point the dealer decided to reverse the rotation of the engines using Suzuki's electronic rotation selection feature and this seemed to help. I suspect having the rotations coming toward each other, as contrasted to away from each other, i.e., where the starboard engine is RH turn and port is LH turn. Has anyone heard of this?
The engines have all the power you would want but you have to be very careful to not over accelerate as the water column just brakes and the motors just ventilate. Currently, at 6,000 RPM I am getting GPS speed at 29 MPH with trim tabs full bow down. If I pull the tabs back, the boat starts to "squat" as the aft drops as does the speed. Very frustrating!!!!!
Lexor Plus 9572-160-19 are 16 dia x 19 pitch 3 blade....not nearly enough...
I had the same acceleration blow out problem with 3 blade 16 x21s on my DF200s
All the zuke/grady expresses that I know of have 4 blade props.
4 blades lift the stern......
...did I mention 4 blades?
if it were me, knowing what I know after trying props on my 265 express with DF200s, I would start with 4 blade 16 x 22s
If you can top out at 5900-6000 with them you'll be doing 40+
If you can't get 5900 then go down to 21 pitch or changed to 15.25 diameter
Also, imho, tabs always screw you. Try testing with tabs all UP, motor trim down, trim up motors once you start to plane
ElyseM
highlands, nj
these are the props i ran. sorry i could not properly post the PB and the Yamaha site didn't have archives. the prop is in RED
i'm not a tech, but even i know there is something wrong with the numbers you posted.
new ones with f300's https://www.gradywhite.com/models/express-cabins/express-330/
good luck, ron (a big assumption is that the bottom is clean)
Yamaha Performance Bulletin
YPB#: PB_GRW_Express330_t_F350TXR_11-6-09_OXP
Performance Data
RPM MPH GPH MPG
1000 6.4 3.1 2.07
1500 8.7 5.2 1.67
2000 10.1 9.3 1.09
2500 12.5 13.3 0.94
3000 21.3 18.8 1.13
3500 27.1 23.1 1.17
4000 32.0 29.1 1.10
4500 35.9 36.7 0.98
5000 39.7 44.9 0.88
5500 43.8 58.7 0.75
5900 47.6 68.3 0.70
Seconds to Plane 6.11
Seconds 0-30 MPH 8.53
Grady-White® Express 330®
Length 33' 10"
Beam 11' 7"
Dry Weight (Boat Mfr. Published) 10,840 lbs.
Maximum HP 700 hp
Fuel Capacity 350 gals.
Weight as Tested (Approximate) 15,455 lbs.
Boat Manufactured By:
Grady-White Boats • P.O. Box 1527 • Greenville, NC 27835
252-752-2111 • www.gradywhite.com
Yamaha F350TXR / LF350TXR
Horsepower 350
Displacement 325.3 cu. in.
Weight (Catalog Published) 804 lbs.
Gear Ratio 1.73
Engine Mounting Height
Mounting Hole Position #1
Propeller
Series Performance XL4 Series
Diameter/Pitch 16-1/8 x 17
Yamaha Part # MAR-GYT4B-V8-17
MAR-GYT4B-L8-17
Propeller Material Polished Stainless Steel
Test Conditions
Number of People 2
Air / Water Temperature (Fahrenheit) 61° / 56°
Elevation 541'
Wind Velocity 0-5 MPH
Comments: Test weight includes 7/8 tank of fuel, six batteries, hard top, safety and test equipment. Fuel consumption
data gathered with Yamaha Command Link® fuel management system. Zero-to-30 speed data gathered with Yamaha
speedometer. Other speed data gathered with GPS receiver.
Notice to Consumer: The information and data contained in this Performance Bulletin is approximate and subject to
many different factors and variables. It is provided as a guideline only and should not be relied upon as representative
of actual performance. Your boat’s performance may be different than the information contained in this Performance
Bulletin due to various factors, including your boat’s actual weight, wind and water conditions, temperature, humidity,
elevation, bottom paint, boat options affecting wind/water drag and/or boat weight, and operator ability. Please confirm
the specifications and performance data on your specific boat/engine combination with your dealer prior to purchase.
Please also keep in mind that the data contained in this Performance Bulletin may or may not have been performed using
Yamaha PowerMatched components. Yamaha reserves the right to change the specifications and performance data of
this Performance Bulletin or engine without notice. This document contains many of Yamaha's valuable trademarks. It
may also contain trademarks belonging to other companies. Any references to other companies ot their products are for
identification purposes only, and are not intended to be an endorsement.
Test Date: 11/6/09
For More Information:
Yamaha Motor Corporation, U.S.A. • OEM Division, Marine Group
1270 Chastain Road NW • Kennesaw, GA 30144 • (800) 88-YAMAHA
For other Performance Bulletins, visit www.yamaha-motor.com.
© 2009 Yamaha Motor Corporation, U.S.A. All rights reserved.
Test performed and verified by Yamaha Application Engineers.
