'87 23' Seafarer hull only asking $6,500 - good deal?
Watch Out
Annapolis, MD
The hull seems to be in great shape, factory mounted motor bracket, never been bottom painted. What do you all think this is worth? How much should I expect to pay in labor only to mount and rig a new motor? Thanks.
capt chris
Ohio River Louisville, Ky./Lake Cumberland, Ky
No matter how cheap, spend the money to have it surveyed and be very suspicious of rotten soft flooring, rotten or wet transom, and corroded fuel tanks just to name a few.
Other than that Mrs. Lincoln, how'd you like the play?
richie rich
south windsor, CT
Capt Chris is correct...20+ years on a boat and things will be developing..in addition to the survey, take her our and see how she runs, and see how it sits in the water...scuppers significantly below the waterline may indicate a heavy core due to being wet...regardless, things like fuel tanks, fuel lines and water hoses and corroded wiring will be in your future unless it was done over by the prior owner...this goes for anytype or make of boat that old....but the GW hull should be solid.
