- Aug 29, 2018
- Age
- 56
- Sailfish
Hello all!
I wanted to see if the following has been encountered before. This boat is new to me and I noticed on the gauge that the upside down triangle is pointing to the oil can/image on the gauge. Now......I am not getting any low oil alarms which I believe is triggered by the smaller oil tank located on the side of each engine that will put the specific engine into limp mode. However, when I read the manual this triangle pointing to the oil can indicates either a clogged remote oil tank filter or low oil in either the remote tank or engine side oil tank. The remote oil tank is full and the engine oil tank is just beneath the top mark. So.....there is plenty of oil in both places. So, I was in the process of replacing the remote oil tank filters and notice that only one of the two remote tanks has a sensor in it. The remote oil tank furthest aft which is the port engine tank does not have a sensor. Thus, this probably explains why the port engine gauge triangle is pointing to green indicating that no oil refilling is necessary?
Before, I go replacing the starboard remote oil tank sensor, should there be one in the port side? is it common practice to have one sensor for two separate remote oil tanks?
Thanks in advance!
John
Thanks in advance!
John
