Gents, The unit on my aux tank reads full all the time, and the tank's bone dry. Searching tells me Wema is the best replacement; think I'll do both tanks. When converting, do I just measure the length of the stocker and buy the Wema's exact same length? Assuming the cable ends are bare. Is it best to just cut off the old harnes and splice in with butt connectors? Don't see any markings on the stockers, are the Wema's same ohms?
While searching I saw a post about the Sailfish fuel directional valves. It said do not use the handle to determine what tank you drawing from. Read the direction arrow on the valve. Not sure what this means can someone elaborate? Think I'm doing it wrong. The valves are labeled port stb and I use the pointer on the handle.
