My 2006 Marlin came with a inexpensive Standard VHF connected to a inexpensive Shakespeare 8' antenna . The antenna is mounted on the stbd. side of the 'hump' on the hardtop, towards the front. In addition there is a small Furuno GPS antenna mounted on the port side of the hump on the hardtop, also towards the front. The Furuno 42" open array antenna is mounted in front of the hump near the front (centered). Finally the mast light is on the hump about three feet behind the leading edge.
I am about to add another 8' VHF antenna (Digital brand) to the hardtop with another SS mount. This antenna will be connected to a Icom 504 VHF. I prefer to keep the antenna wire in the electronics box (towards the front of the e- box). However, I do not want any interference with the other electronics.
Where do you guys recommend I place the second VHF antenna? Is there a standard to keep antennas away from each other?
