- Jul 17, 2009
Could use some advice as to where to put the inlet {best place}
I pretty much have most everything needed,I'll be adding a main-in breaker panel with 2 breakers,dei galvanic isolator,gfci outlet,and the inlet.
we have an on board 2 bank charger that I'm going to run into 1 of the breakers on the main-in panel.
{last year we were using an adaptor/extension cord setup and it was a pita.}
the 2nd breaker off the panel will be an outlet somewhere in the cabin ?
where would you guys install the inlet,and somewhere near the inlet in a dry location will be the galvanic isolator. {Just not sure wheres the best place to put them ?} perhaps the gfci location as well !
thanks,
thanks,
