Guys I know who have them have seen a slightly quicker time to plane on bigger boats, and a little less trim climb when getting on plane, but on bigger boats you will not see an improvement on fuel economy by much except at lower speeds where the boat used to plow and now you can plane out, might gain maybe a 3mph range down low where you plowed before and can now hold plane. You will still have a big trim, but might be able to decrease it by 2 degrees roughly by adding these. Typically you can do the same thing with your tabs, also put your engines lower when coming onto plane them trim them out for running, my boat climbs and has a big trim angle coming on plane if I have the engines trimmed for running, if I put them down I do not get it and come on plane easier, but then I trim them out for best economy once on plane if covering enough groud to be worth it.
Only thing to watch out, typically the second you fasten those foils on you void any warranty the engine has, depending on the dealer they may over look it, but there are many that will blame that and say it voided the warranty, I believe it does state it in many engine warrantiess that any modifications void it and this would clearly fit that. I know it is a rebuild, but typically they have a 1 year warranty so it may warrant waiting a year and looking into playing with the trim tabs before spending the money that might not be needed and would void your warranty before it is up.
