2004 232 Gulfstream with twinF150 Yamaha's
I have twin 2004 F150 each with starting batterys. Both battery's have switches and charge it's respective battery. I want to add a house battery (third battery). I understand each engine has Aux charging plugin and I have to buy the Battery Isolator Lead and direct it to the +post of the third battery. What is the part number? When I am running what are the amps to the starting battery(main Isolator Lead) and what will be the amps to the Aux lead? I understand the max amps at cruise is 35A per engine, don't know the idle amps. Is the charging discriminating(the weakest battery gets more amps) or are the leads regulated?
Thank you,jim
Thank you,jim
