Adventure 208 Seat Replacement
v8boatbuilder
Holmdel, NJ
I'm looking to replace the seats on my 99 Adventure 208? For those who have done it, what brand/model did you use?
You are a bit limited in choices since those seats are fairly narrow. The outer sides come very close to the helm walls.
Your seats may be Todd.
This seat is close.
The outer dimensions are the critical specs.
The seats don't generally include the mounts. There are lots of options, the two key measurements are the pedestal diameter (2 7/8 for yours I suspect) and the seat mounting bolt spacing. You can reuse your old mounts but by now, things like the slide guides are probably worn out.
CJ7Rob
If you decide to sell the ones you have on your 208, I'd be interested. I'm also in NJ, can pick up, Thanks
