- Oct 28, 2019
- Age
- 45
- Islander
I have a 1995 Islander 268. This past tropical storm that came up confirmed that the current configuration is not going to last. See pictures. It appears the pendant lines from the mooring damaged the pulpit as the boat was bouncing due to there only being one central cleat at the base of the pulpit just after the anchor locker... not long after that I was rafted up with a neighbor who has a much bigger boat and one of his dock lines popped off one of the guides that leads to that one bow cleat.
Ive noticed other boats in the field with cleats on either side of the pulpit anchored into the boat (picture with red circles indicate general area I would mount new cleats) which looks like it would make more sense and have better separation. Im thinking of doing the same thing but was wondering if anyone else has done this themselves... would need to pull down the lining in the berth as I think I would also need to install backing plates under the new cleats and not just drill them into the fiberglass and forget it.
Questions -
1) backing plates a neccessity vs just an underside bolt?
2) Is there a difference between an open based cleat and a hollow based cleat?
- reason I ask this I couldnt find a definition and judging by pictures I could not see a significant difference. I need a 6" cleat Im thinking however, need enough clearance off the deck so the thick pendant line can slide through.
Thanks for reading.
Questions -
Thanks for reading.
