- Jul 25, 2021
- Age
- 63
- Marlin
I've struggled with the plastic engine flush system on my Marlin 300 - - both broken parts and generally difficult to get the connector to plug into the valve. While GW did replace the parts that failed under warranty, I decided to look for a better engineered approach. For clarity, it needs some kind of valve to maintain it as a closed system when the engine is running. I was able to locate everything I needed on Amazon in Stainless Steel, picked up a new plate on Ebay for about $15.00 and installed everything today. I'll see how it holds up, but my post-modification testing was all positive - - no leaks, fit in the standard mounting plate and I now connect the hose directly with no adapter necessary. Photo is attached - - the brass caps are just added safety if the valve were to fail or if something rubs on it and opens it. Here's the parts list from Amazon if anyone is interested.....
And, if you happen to use the beduan stainless spigot toss the poly washers that it comes with and use rubber hose washers. The poly washers provided aren't sized correctly and push into the valve causing leaks. Once I tossed the supplied washers and used the extra rubber ones from the brass connectors everything was fine. I did use teflon tape on all connections.
Not pushing this on anyone, just sharing an alternative as I've talked to a lot of GW owners who struggle with the GW flushing system and/or dislike the need for the adapters on the hose.
