- May 6, 2015
- Misquamicut, RI & Melrose, CT.
- Freedom 255
Went out fishing for a couple of hours this morning. On the way back to the dock, I ran over an on-coming vessel's wake and came off the back side of it pretty hard. After washing down the boat at the dock, I went to button up the canvas due to bad weather coming tonight. All morning I ran the boat with the walk-thru window open since it was warm out. I went to close it and discovered it is over-lapping a bit at the top of the frame and would not fall through. I monkeyed with the support and was able to give it enough clearance to close but I can see that it is a bit off from top to bottom. My guess is that I tweaked something coming off of that wake and now need to figure it out.
If any other DC owners encountered a similar issue, please advise where you began to troubleshoot. Thanks.
