jellyfish said:
yep, working on old boats will teach you things you could never learn in school. Anyway heres what we found, Float was bad, and the wires that go from the switch in the rocker panel was shot, good thing that Grady did was run an extra wire from the aux switch back to the pump, so we used that and hooked it up to the switch and it now works. The switch was fine and the extra wire for the aux was not being used for anything. So everything is now a go. I need a replace a few bad wires that are looking bad. So thats my next project. Check your floats!! Thanks for all the great advice everyone gave me, it made the job go by faster. Now I can get back on the water.
Congrats!
Yes, the dreaded black wire is the sign of corrosion, inherent in all older boats, GW or whatever. It occurs simply from the environment boats exist in. What the result is is that the resistance in the circuit increases, thus the current flow decrease, resulting in a drop in voltage/amps, as well as an increase in heat. All these negative factors result in the appliance, whether it be a pump or a light, work less efficiently, or at higher temperatures, resulting in shortened lifespan.
Trust me, take any lead off your helm switch panel, cut the terminal off, strip back some insulation, and tell me what you see...it will be black, as once corrosion starts wicking up your harness, it will go everywhere.
I used to work on a '98 Proline 2950 that had corrosion so bad, I had breakers that checked 12V on the input side and 9V on the output side! 3V in less than an inch!
I think what a lot of owners here on GreatGrady are seeing in regards to the electrical system problems on their boats is due to corrosion. But they shouldn't feel alone...
