Re: Anyone have pics of Roll control dive tank rack on Marli
Nick,
I have (had) the roll control setup on both my 330 Express as well as previously on my 272 Sailfish. On the Sailfish, there was room under the coaming pads to mount the rails directly to the fiberglass beneath them without having to remove/replace the pads. I used some spacers I found at Home Depot to have the racks spaced out enough so that with the tank holders in, the scuba tanks would stay "snapped" in them.
On my 330 Express, the pads cover all of the fiberglass, so I took the pads off and fabricated aluminum brackets to hold the roll control rail just below the pads. I mounted the fabricated aluminum extensions to the fiberglass and also to the roll control rail using countersunk SS screws. With everything screwed together, I then put the coaming pads back on. Nice clean setup with no hardware showing and strong. I carry 5 tanks on each side (we are diving the bigger diameter steel 117 and 130 cu ft tanks).
No pictures handy. If I get down to the boat in the next couple of days, I will take some pics and post them.
Jim
