I went by my material supplier today to get some ideas on a finishing coat to repaired areas. I was under the impression that epoxy would not adhere well to the gelcoat. They informed me that epoxy will adhere very well to gelcoat, especially to older porous gelcoat, but gelcoat will not adhere well to epoxy.
I also asked about paint finishes. They recommended the "Sterling" two part product as top shelf product with 12+ year endurance, mirror like finish, for exterior hull, but not for cockpit topsides, helm, etc.. Said it is so shiny that it will create glare in these areas. It can be rolled and tipped.
They also recommended "System Three Topcoat" product for use in cockpit area. it is a polyurethane paint. I purchased two small 4oz containers of this, and plan to coat the splash area with it. This way, I'll see how it goes on and looks.
I'm hoping that this "system three" coating will work out well in the splash and raised transom areas, then I can move on and install twin outboards. I really need to get them out of my garage. Between the two motors, and all the related hydraulic steering, harnesses, controls, helm, etc., it is dominating a significant portion of the garage. If I can get them hung and set up, then I can get back to finish coating on remainder of hull at a later time.
I'll get some pics up of finished coating as soon as I get it on. Thanks again for info. Mike
