- May 8, 2014
So, I got everything wired up and connected - the pump, the HDS, the NAC-1, and the AP-1... That all worked...
What didn't work was the hydraulic fittings... I have the NPT, "old-syle", helm... But with the constraints on space and routing lines, I wanted to use ORB fittings...
The only ORB-F to NPT-M I cound find was #4 to 1/4"... I then used #4 ORB elbow, a #5 to #4 reducer, the the #5 tee to the hydraulic lines... In my case, the reducer didn't work - it leaked like a sieve...
What I need is a #5 ORB-F to 1/4" NPT-M, then a #5 ORB-F to #5 ORB-M elbow - anyone know where I can get these parts? Anyone successfully adapted an NPT helm to ORB on a 265 Express, where it has to be routed 90 degrees away from the helm?
