gwwannabe said:
Chris, This chart is a bit misleading. It is for batteries USED IN DEEP CYCLE APPLICATIONS. That why the starting battery life is so short.
Gary 89 Overnighter
Yes, from wind-sun site, I quoted my source. Not intended to mislead anyone.
A lot of guys will purport the use of cranking batteries on our boats, and this is why I disagree with that. If you are powering a plethora of accessories, like finder/plotter, radio, bait-well pump, lights, stereo, radar, the list can be long, then you're running your batteries down at drift or idle, and this is precisely what kills batteries that are not rated deep cycle. Even some of the cheaper deepcycles are not really such, they have thinner plates and aren't built well enough to endure repeated discharging.
Cranking batteries work great for that purpose, and if you have one it should be used only for such - one for each engine, used only for starting, or kept in reserve for starting, run everything else off a deep cycle.
So when one asks the question, 'How long will my batteries last?', the answer is really, what kind of battery did you put in there in the first place, how did you maintain it, and how did it get used?
My intention was to provide information to help one seek knowledge, not to answer the question directly. :wink:
