Bennett Trim Tabs - Problem Resolved
Capt Armchair
This is for the benefit of anyone who has a problem in the future.
My trim tabs would not deploy. On a 2004 Marlin, the pump is on the port side panel (on the wall) in the v-birth.
1. Check the fluid in the pump unit, fully deployed the fluid should be about 2 inches from the bottom
2. There is a fuse, Grady retrofitted the inline fuse that comes as a stock part on the actual switch mechanism with a 20a fuze in the small fuse panel under the helm. THe power line is the orange one.
3. In my scenario, the switch would not work. So I bypassed the swich using the following guidelines, from Bennett.
  • Orange ( + ), blue, red Port trim tab down
    Orange ( + ), blue, green Starboard trim tab down
    Orange ( + ), blue, red, green Both trim tabs down
    Orange ( + ), yellow, red Port trim tab up
    Orange ( + ), yellow, green Starboard trim tab up
    Orange ( + ), yellow, red, green Both trim tabs up
Crossing wires made it work, bought a new switch and good to go. The folowing link is a useful troubleshooting guide for Bennett Trim tabs.
http://www.bennetttrimtabs.com/pdf/trob ... ooting.pdf
Cheers-
Don
