I brought the boat (19 ft tournament 140 Suzuki) on Thanksgiving Vacation and launched it and docked it at the local Marina. Figured with some decent weather (North Carolina, Emerald Isle)we could cruise and fish a little before putting it away for the season.
Thursday was excellent and all was well until today. I went over to check on the boat and it had about 1 inch of water in the floor, the entire bilge was full. A few things caused the problem. First, a Bow line loosened up and the boat drifted back allowing the outboard to go under the dock. When the tide came in, the motor got stuck and kept the stern down. The water eventually came over and the bilge pump float failed. Fortunately, the pump still worked on manual.
Luckily, the motor was fine, a small chip in the plate above the prop. I pumped it out and all seems well.
I know it was a stupid mistake and I secured the bow line correctly. Is there any other issue that could cause a problem ? Tomorrow I plan to pull the boat, pull the plug and drain it again, then hopefully go for a ride to test everything.
