My command link speedo is way off. My Transducer says im goin 22mph and the Command link says 17mph or 9mph. Just started this worked fine until now.. Anyone have any input??? I tryed Searching on the web with no luck...
You need to clean out your Pitot hole on the motor. On the front of your of your skeg about even with your driveshaft you will see a little tiny hole. It get's plugged up over time with junk and that throws your speedo off.
I usually use a small drill bit and it cleans right out. Can't remember right now but I believe I use 1/16" drill bit but if not then it's 1/8".
