Curtains up or down
Bdsp1234
While slipped in heavy wind of 35-45 sustained, do you roll up the curtains or leave them down and zipped in place.
Cregan13
Wilmington, NC
Taken down completely, both to reduce windage and to avoid damage to the curtains themselves. 15 minutes of work is a small price to pay to avoid having to replace busted curtains.
Legend
Southern New England
35-45 is a pretty common wind where we are so mine would commonly be zipped for that. Definitely remove if it is forecast to reach hurricane force.
SmokyMtnGrady
in a storm situation I would take them off. however, they can take 40 mph wind because they can take your boat going 40 mph for extended period of time while being down.
Cregan13
Wilmington, NC
Just be sure 35-45 is the max winds, and not the forecast sustained winds. Lots of storms will have gusts significantly higher than the sustained. We had gusts here into the 90s, even though the max sustained were in the 50s and 60s.
Captain TJ
Port Orchard, WA
Also remember boat traveling 40 mph is into the wind not that speed from behind. Just a thought.
Capnjim7
Also...If you decide to not leave the curtains zipped in place take them off. If you roll your curtains up in a storm and leave them that way you will get moisture with salt and sand between them that will chafe. Then after the storm the heat from the sun will cause hazing and discoloration. Never a good idea to leave curtains rolled up for anything but a short ride.
Bdsp1234
All, I decided that it is best to have the curtains up. We did get wind gusts to 70. I didn’t want to take that chance. I will bring them down again tomorrow.
