- Apr 27, 2005
- Long Island, NY
- Sailfish
Don't forget to service your deck plate O ring seals.
Not one drop of water is to pass onto the top of the gas tanks below, if you care about tank life longevity.
Take out the cap the day after it rains, is the tank top bone dry?
Gently take the o ring out of the cap groove, clean it gently, clean the grove on both cap and base. Inspect o ring, any cuts, nicks? Same for groove.
Reinstall, if the cap is not snug, get a new o ring and try first. If you palm the cap and try to twist it (pry type) I don't think you should be able to rotate it readily.
Do same inspection and cleaning process for screw type.
Do same inspection and cleaning process for gas tank fill caps, oil tank fill caps, FW water tank fill cap.
