panhdjoe said:
Hello all, I have a 1995 192 tournament dual consoul (Sea V2 hull). My problem is that My Garmin 440s looses its depth readout almost every time I plane out. I have adjusted it at least 5 times and now it is sitting on the transom exactly the way shown in the drawing in the Garmin installion manual. No amount of tweaking the adjustment has helped much. Question: is this a common problem on boats with this hull? Is this a common Garmin problem? I am considering swaping on a Lowrance HDS 5 I have on my big boat but I will need to replace that, and not 100% shure it will solve the problem.
Looking forward to some shared wisdom. Thanks Joe
Assuming there is nothing in front or next to the ducer that causes turbulence, it should work. It should be at least 2 inches away from chines or the like and not behing something like a water strainer. The first thing to try is tilt up the rear of the transducer so that it is not parallel with the keel but will be parallel to the sea floor when on plane. While you are at it check the depth of it. Put a straight edge on the hull and see where the bottom of the ducer is. It should be a tad below, maybe an eighth to a quarter of an inch. The bottom may be losing contact with the water and might need to be even lower. Sometimes trim tabs will lift the stern up and the ducer depth gets too small or goes away. Finally, check the ducers bottom for barnacles or any growth. Even small pieces of gunk will cause turbulence and air bubbles.
