Does anyone know what these are called
Norcoastal
This is from an older Grady Seafarer, it holds the small bow hatch down.
Any idea what they’re called and where I can find one?
Im sure they aren’t made any longer. Any suggestions of what I can use in its place?
Looks potentially like a Moonlite Marine hatch latch part number 0100-2 which they have them on eBay as well as a handful of other sites like Zoro. Though, I've honestly not used that website before. Check the Moonlite Marine website and see what length you have, as though it appears they have two different versions. Of which you might be able to just order it from MM as well as well as a few other different sites. Good luck!
gw204
St. Leonard, MD
I think they are also made under the Sea Dog or Seasense name. That being said, I've got an OEM Grady one if you need one...complete with hatch and gutter from a 227.
Norcoastal
That’s very nice of you, thank you. I worked on my bracket and got it loose with some WD-40 and vise grips. The handle crumbled some, but I think I’ll be ok. But thank you again!
