- Oct 17, 2021
- Age
- 36
- Fisherman 222
I have a 1999 GW Fisherman 222 and noticed what seems to be an electrical issue.
Today we were preparing to leave the sandbar, started the engine, turned on the electronics and the engine suddenly died. Went to restart it and noticed I had no power to the gauges and no power to the engine. The electronics powered up fine. I checked all the connections from the battery to the engine and all were tight. Still no power to engine or gauges.
I finally got the engine to fire again after swapping around a 10a fuse in the fuse holders (one is for the auto Blige and one is for the memory). As I began trimming the engine down it cut out again. I noticed that 10a fuse in the memory fuse holder blew. I changed it out and it fired up. I shut down all unnecessary electronics and did not use my trim. Got it back home.
Once home, I began digging into the battery box more. I noticed the original 40a breaker box is badly corroded as is the 10a fuse holder for the auto Blige.
I plan on replacing the breaker box, the fuse holders, and all ground and positive cables going from the battery, breaker box and battery selector.
Does this sound like the correct thing to do, anything else to check?
